Warning
A NetSuite JDBC connection is considered a separate endpoint from a standard NetSuite connection. For more on endpoint capacity, see How much capacity your account has.
A JDBC connection allows you to access NetSuite SuiteAnalytics and conveniently fetch large amounts of data.
The NetSuite JDBC connection offers certain advantages over integrating with NetSuite via Saved Searches. In general, NetSuite JDBC is best suited for integration developers with SQL expertise; the statements needed to mimic the NetSuite web interface can be complex for beginners.
Consider selecting NetSuite JDBC if you have any of the following requirements:
- Complex joins, which can’t be accomplished in a Saved Search with the single-layer join limit
- Exporting large amounts of data for analytics
- More quickly exporting large amounts of data in your flow – for example, an entire transaction history with 50+ columns and hundreds of thousands or millions of records
- Reducing API usage, since NetSuite JDBC is not typically governed by NetSuite concurrency restrictions
- Have access to a paid NetSuite SuiteAnalytics Connect subscription
Click to open the Build SQL query editor and ask Celigo AI to generate a query. Enter a description of your query in plain English in the space provided, and Celigo AI will attempt to generate a query based on your prompt.
Before connecting to NetSuite JDBC, follow the steps in the linked articles.
NetSuite deprecation notice: With the NetSuite 2026.1 upgrade, the NetSuite.com data source will be removed. Queries using this source will no longer run. The NetSuite JDBC connector will no longer allow selection of older schemas in new connections. Users should update existing connections to NetSuite2.com to maintain compatibility.
After you start the connection , you have to configure it in the Create connection panel and complete all of the required * authentication settings:
| Application details | Description | |
| Server name * | Enter the NetSuite SuiteAnalytics Connect server TCP/IP address, shown as Service Host in NetSuite. To retrieve it, navigate to NetSuite Home page > Settings portlet > select Set up SuiteAnalytics Connect, and expand Your configuration. If the link isn't there, enable SuiteAnalytics Connect first, in Setup > Company > Enable Features > Analytics. | |
| Port number | Displays 1708 and cannot be edited. This is required while configuring the data source in NetSuite. | |
| Server data source * |
Select the NetSuite SuiteAnalytics Connect server data source, either NetSuite.com or NetSuite2.com. NoteAs of November 8, 2021, new Connect users can access the Connect Service using the NetSuite2.com data source only. If you gained access to the Connect Service before this date, you can still access the NetSuite.com data source to ensure a smooth transition to NetSuite2.com. Note that the NetSuite.com data source is no longer being updated with newly exposed tables and columns, and support for this data source will end when your account is upgraded to 2026.1. The use of the NetSuite.com data source is no longer considered a best practice, and all Connect users are encouraged to use the NetSuite2.com data source. For more information about this change, see New Accounts and Access to the Connect Data Source. |
| NetSuite.com * | ||
| Username * | Enter the username for your NetSuite account. | |
| Password * |
Enter your NetSuite password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
| Account Id * | Enter your NetSuite Account Id. Navigate to Setup → Integration → Web Services Preferences. If you can’t find your Account Id here, contact NetSuite’s support team. | |
| Role internal Id * | Enter the Internal Id associated with your user’s Role. Determine the user you’re using for this connection. Navigate to Setup → Users/Roles → Manage Roles. If your settings automatically display the Internal Ids, find the proper Id and add it to the connection. If the Internal Id is not automatically displayed, open the Role in View mode and use the URL in your browser to find the Id. Contact NetSuite's support team if you can’t find your Role Internal Id. | |
| NetSuite2.com * | ||
| Static schema export * | Choose Yes to use the static data model, which provides the structure, the name of all available record types, and the fields in the NetSuite2.com data source. (To use the static data model in your account, you must add the StaticSchema attribute and set it to 1.) | |
| Authentication types * |
Choose between: |
