Set up a manual token-based auth connection to NetSuite
Netsuite documentation: Authentication
One additional NetSuite authentication type is available: token-based (automatic) . However, if you are installing an integration app or adding a connection to one, you must establish your connection to NetSuite according to the integration app’s instructions. For example, see Install Salesforce - NetSuite (IO).
Before you begin
Before you begin, read Before you connect to NetSuite.
A. Set up a NetSuite connection
Start establishing a connection to NetSuite in either of the following ways:
    – or –
In the resulting Application list, select NetSuite.
B. Describe your NetSuite connection
First, name your connection in the General settings:
C. Supply required NetSuite account information
At this point, you’re presented with options for providing NetSuite authentication.
Authentication type (required): Select Token Based Auth (Manual).
Environment (required): Enter the NetSuite environment you want to connect with: a production, sandbox, or beta environment. NetSuite must provision Sandbox NetSuite accounts, and beta environments are typically available only in the weeks prior to a NetSuite upgrade.
Account ID (optional): Enter your account ID. Contact NetSuite support to obtain the ID if it’s not exposed in the following steps:
Make sure you use underscore (_) instead of dash (-) while you enter your account ID. For example, if your account ID is 12345_SB1.
Token ID (required): Enter the required token ID. Before creating an access token in NetSuite for integrator.io, verify that you have installed Celigo integrator.io SuiteApp (ID 20038) in your NetSuite account, which creates the role Celigo integrator.io Full Access Role w/o 2FA [Locked]. When you create the access token in NetSuite, select integrator.io as the Application (step 6 under “How to retrieve your token and token secret”). A token created for any other application is refused when the connection is saved, with Invalid login attempt and no further detail in integrator.io; the fix is to create the token again for integrator.io. After the token is accepted, integrator.io records the connection’s user and role from the token — there is nothing to look up or enter.
Token secret (required): Enter the value retrieved with your Token ID, above. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s Token ID and Secret safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
iClient (optional): Leave this empty for a standard NetSuite connection. A standard connection signs in as Celigo’s own integrator.io integration record, so there is no client ID or client secret to get from NetSuite. Select an iClient only if your connection authenticates as your own NetSuite integration record or as an Integration App’s integration record (for example, “eTail Connectors (Token-Based Auth)”); then the access token must be created for that application instead of integrator.io. To add an iClient and configure your credentials, click the plus (+) button. Click the edit (pencil.svg) button to modify a selected iClient. Be sure to give the iClient a recognizable name for use in any other connections.
How to retrieve your NetSuite account ID
  1. Sign into your NetSuite account.
  2. Click Setup.
  3. Navigate to Company > Integration > SOAP web services preferences > Primary information.
  4. Copy Account ID.
  1. In NetSuite, go to Setup > Users/Roles > Manage roles; then click Customize corresponding to the role Celigo integrator.io Full Access Role w/o 2FA [Locked]; and save the role (clone) with a different name.
    Celigo integrator.io Full Access Role w/o 2FA [Locked] is a locked custom Celigo role. When cloning the role, you can add additional permissions to the role to fit your requirements.
  2. Navigate to Manage roles to verify the presence of Celigo integrator.io Full Access w/o 2FA [Locked].
  3. Go to Manage users, select a user, then click Edit to modify the user.
  4. Click the Access subtab at bottom of the screen, then the Roles subtab.
  5. Add the custom role that you just created, then click Save.
  6. Go to Setup > Access tokens > Create access token. You must add “integrator.io” in the Application field for all access tokens the Celigo platform uses.
  7. Copy the Token ID and Token secret to a safe place, since they will not be shown again.
D. Edit advanced NetSuite settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the NetSuite connection.
Link SuiteScript integrator (optional): This setting appears only when you edit a NetSuite connection. Prior to integrator.io, NetSuite integrations built by Celigo ran directly inside your NetSuite account via a managed bundle. If you are still running any of these older integrations, check this box to link integrator.io to your NetSuite account.
WSDL version: New Web Services Description Language (WSDL) versions are available when creating or editing a NetSuite connection. A WSDL is simply an XML document describing the latest versions of a web service. By choosing a WSDL you are choosing to upgrade to a new or older version of NetSuite’s web services.
You can choose between versions 2025.1 and 2023.1. Versions 2023.1 and later support both manual and automatic token-based auth connections. Switching versions for an existing connection might have an impact on running flows, and we recommend reviewing NetSuite’s release notes prior to making a change. We recommend using the latest WSDL version.
E. Save and test the connection
Once you have configured the NetSuite connection, you have a few options for continuing:
