Sage Intacct is cloud financial software that helps to meet the accounting demand from small organizations to public companies.
To obtain the Sender ID and Sender password, you must have access to the Sage Intacct Web Services developer license. For more information, see Requirements.
API type * |
Choose your Sage Intacct account API type:
API type: XML |
Sender ID * |
Enter your Sage Intacct sender ID. |
User ID * |
Enter your Sage Intacct web services user ID. |
Company ID * |
Enter your Sage Intacct company ID. |
Sender password * |
Enter your Sage Intacct sender password that you received in the email after creating the sender ID. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s sender password safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
Password * |
Enter your Sage Intacct account password that you received in the email after creating the web service user. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
API type: REST |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Sage Intacct. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource How to retrieve the client ID and client secret: |
Grant type * |
Select your application grant type:
Client ID * |
Enter your Sage Intacct client ID. |
Client secret * |
Enter your Sage Intacct client secret. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s secret safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
Username |
Enter your Sage Intacct username in NoteProvide either the Username or the Session ID to establish a successful connection. How to retrieve the user ID, company ID, and entity ID: |
Session ID |
Enter your Sage Intacct account API session ID. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the respective documentation for OAuth 2.0 auth and Token auth universal connectors.
Sign in to your Sage Intacct account.
From the Applications dropdown, click Company.
Navigate to Setup > Configuration > Company > Security.
From the Web services authorizations section.
Copy the Sender ID.
Navigate to Admin > Web services users.
From the Web services users list, copy the required User ID. If the web service user is not added, click Add. For more information on how to add a user, see Add a web services user.
Navigate to Setup > Configuration > Company > General information.
From the Company Information section, copy the ID.
Sign in to your Sage Intacct admin console.
Navigate to My account.
Click Create app. For detailed information, see How to create an app.
Enter an App name.
Enter your Email address.
Enter the Celigo Redirect URL.
Click Save.
Copy the Client ID.
Copy the Client Secret.
Navigate to Setup > Entities.
Click + (if you created an entity, click Edit and copy the Entity ID).
Enter and copy the ID. For detailed information, see Add an entity to your company.
Enter a Name.
