Set up a connection to Bloomreach
Bloomreach is a leading digital experience platform that helps businesses deliver personalized and optimized online experiences to their customers through AI-driven search, content management, and commerce solutions.
Setting Instructions
Name your connection * Enter a clear and distinguishable name.
API type *
Choose your Bloomreach account API type:
  • Engagement: Get tracking, customer, catalog, email, import, export, GDPR, and analysis details
  • Content delivery: Get delivery images, documents, assets, and folder details
  • Content management: Get documents, pages, resource bundles, and folder details
  • Discovery: Get catalog management details
API type: Engagement
Project token *
Enter your Bloomreach project token.
Fetch data How to retrieve the project token
Auth type *
Select your Bloomreach authentication type (either Basic or Token).
API token *
(This setting is only applicable with Token auth type)
Enter your Bloomreach public API token.
Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Fetch data How to retrieve the public API token
API key ID *
Enter your Bloomreach private API key ID.
Fetch data How to retrieve the private API key ID
API secret *
Enter your Bloomreach private API secret.
Multiple layers of protection, including AES 256 encryption, are in place to keep your API secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Fetch data How to retrieve the API secret
API type: Content delivery
Subdomain *
Enter your Bloomreach account subdomain. For example, if your account URL is https://cloudapi.bloomreach.io/delivery then, cloudapi is your subdomain.
Token *
Enter your Bloomreach content token.
Fetch data How to retrieve the token
API type: Content management
Token *
API type: Discovery
Environment *
Select your Bloomreach Discovery account environment (either Production or Sandbox).
Token *
Enter your Bloomreach discovery token.
Job ID *
Enter your Bloomreach job ID.
Fetch data How to retrieve the job ID
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token, and basic universal connector documentation respectively.
  1. Sign in to your Bloomreach account.
  2. Navigate to Project settings > Access management > API > API groups.
  3. Copy the project token.
  4. Click + New group.
  5. In the Access type, select Public access.
  6. Enter a Key name
  7. Click Create group.
  8. Copy the API token. For more information, see API groups.
  9. Copy the API key ID
  10. Copy the API secret.
  1. Sign in to your Bloomreach content account.
  2. Navigate to Setup > brXM API token management.
  3. Click + API token.
  4. Enter a Token name, and select an Expiration date.
  5. Provide the Access and click Create.
  6. Copy the Token. For more information, see Instructions
  1. Sign in to your Bloomreach discovery account.
  2. Navigate to Setup > Catalog management > Jobs.
  3. Search for the required job.
  4. Copy the Job ID. For more information, see Jobs
