Set up a basic auth HTTP connection
Basic authentication documentation: Standard
You can build integrations with apps that use HTTP with basic authentication, even if the connection is not already provided by integrator.io.
Before creating the connection, review your app’s API guide. It will provide the information you need, such as the kind of authentication that the app requires and its URI. Every app puts its documentation – guides and reference material – in different places. You can often find it by searching for “API guide” or “API documentation” on the company’s website.
A. Set up an HTTP connection
  • Select Connections from the Resources menu.
  • Next, click + Create connection at the top right. In the resulting Create source panel, select HTTP from the Application list, under the Universal connectors group.
  • While working in a new or existing integration , you can add an application to a flow simply by clicking Add source or Add destination/lookup. From the Application list, under Universal connectors, select HTTP.
image idm45505574281232
  • After the HTTP Application is added, click the Connection setting’s + button to proceed.
C. Edit basic auth settings
Continuing in the Create connection pane, select Basic for the Authentication type. The settings then become specific to basic auth. At a minimum you must provide your username and password to establish a connection.
Username (required): Enter the basic authentication username for the server.
Password (required): Enter the password for this account. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text.
D. Edit common HTTP settings
  • Application details (contains the required settings Base URI and Media type)
  • Nonstandard API rate limiter
  • How to test this connection?
  • Advanced
E. Save, test, and authorize
