Ceridian Dayforce is a global human capital management (HCM) software that provides human resources, payroll, benefits, workforce management, and talent management capabilities in a single solution.
Company ID * |
Enter your Ceridian Dayforce company ID. For example, if your Ceridian Dayforce url is
Subdomain * |
Enter your Ceridian Dayforce subdomain. For example, if your Ceridian Dayforce account is located at |
Auth type * |
Select Basic as the authentication type for this connection (the token option is described separately). |
Username * |
Enter your Ceridian Dayforce account username. |
Password * |
Enter your Ceridian Dayforce password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
Environment * |
Select the environment type. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Basic universal connector documentation.
