Set up a token-based auth connection to LiquidPlanner
LiquidPlanner is an online project management software company. It dynamically adapts to change and manages uncertainty and helps teams to plan, predict, and perform to expectations.
This video demonstrates creating a LiquidPlanner connection.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings.
Setting
Instructions
Name your connection *
Auth type *
Select Token as the authentication type for this connection (the basic auth option is described separately).
API token *
Enter your LiquidPlanner API token.
Multiple layers of protection, including AES 256 encryption, are in place to keep your API access token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the API token
  1. Sign in to your LiquidPlanner developer account.
  2. Navigate to My API tokens > Add new token.
  3. Click Add new token. The Description window appears.
  4. Enter a unique name and click Save.
  5. Copy Token.
