LiquidPlanner is an online project management software company. It dynamically adapts to change and manages uncertainty and helps teams to plan, predict, and perform to expectations.
After you start the connection , configure it in the Create connection panel and complete all of the required * authentication settings.
Auth type * |
Select Basic as the authentication type for this connection (the token option is described separately). |
Username * |
Enter your LiquidPlanner account username. |
Password * |
Enter your LiquidPlanner password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic auth universal connector documentation.
