Tallyfy is workflow and process management software that helps you to automate tasks, document processes, and track workflows.
This video demonstrates creating a Tallyfy connection.
Token * |
Enter your Tallyfy token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token universal connector documentation.
Sign in to your Tallyfy account.
Navigate to Settings > Integrations > Authentication > REST API.
Click View your API access token.
Click Copy.
