Tallyfy is workflow and process management software that helps you to automate tasks, document processes, and track workflows.
Auth type * |
Select OAuth 2.0 as the authentication type for this connection (the token option is described separately). |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Tallyfy. To retrieve client ID and client secret, contact the Tallyfy support team. To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit ( |
Scopes * |
Scopes are OAuth 2.0 permissions that Tallyfy defines to limit access to your account
