Lever is recruiting software that helps talent teams scale recruitment efforts and hire people faster.
Account type * |
Select your Lever account type: Production: if your Lever account URL is Sandbox: if your Lever account URL is |
Auth type * |
Select Basic as the authentication type for this connection (the OAuth 2.0 is described separately). |
API key * |
Enter your Lever API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic universal connector documentation.
Sign in to your Lever account.
Navigate to Integration and API > API credentials > Lever API credentials.
Click Generate new key.
Enter Name.
Select the required Scopes.
Click Save.
Copy API Key.
