Lever is recruiting software that helps talent teams scale recruitment efforts and hire people faster.
Account type * |
Select your Lever account type: Production: if your Lever account URL is Sandbox: if your Lever account URL is |
Auth type * |
Select OAuth 2.0 as the authentication type for this connection (the basic option is described separately). |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Lever.
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit ( |
Scopes * |
Scopes are OAuth 2.0 permissions that the Lever API defines to limit access to your account. |
Sign in to your Lever account.
Navigate to Integration and API > API credentials > OAuth tab.
Enter Integration name.
Enter Description.
Enter your integrator.io Callback URI.
Upload your Logo.
Select the required Scopes.
Click Done.
Copy Client ID.
Copy Client secret.
This article is concerned only with the settings needed for creating OAuth 2.0 client for Lever. For complete field documentation, see Create a new iClient.
At this point, you’re presented with a series of options for providing OAuth 2.0 HTTP authentication.
Name (required): Enter the required iClient name.
Client ID (required): Enter client ID (retrieved from the above section).
Client secret (required): Enter client secret (retrieved from the above section).
Account type (required): Select the account type (Production or Sandbox).
Click Scope.
To access all of the scopes in the API, click the » button.
– or –
Click Save.
