HiBob is an HR platform that simplifies people management, modernizes the work experience, and brings out the best in every employee.
Environment * |
Select your HiBob account environment type:
Auth type * |
Select Token as the authentication type for this connection (the Basic option is described separately). |
Token * |
Enter your HiBob token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your HiBob account.
Navigate to Profile > API access.
Click Generate token.
Copy the Token.
