Disable Celigo Ora
Ora lets you interact with integrator.io using natural language via an AI-powered chat interface. It allows you to build SQL queries and handlebars templates. Ora is enabled by default.
  1. Log in to integrator.io.
  2. Click the avatar in the upper right corner of integrator.io, click My profile, and clear the Ora checkbox.
  3. Click Save.
