Create or explain filter rules using Celigo Ora
For users with minimal programming experience, Celigo Ora simplifies creating and explaining filter rules for input or output filters. Define the use case in a plain English prompt, and Celigo Ora will generate the filter rules without requiring you to create them manually. You can describe filter rules that include multiple fields and complex use cases.
Celigo Ora must be enabled in your integrator.io account. Click the avatar icon in the upper right corner of integrator.io and click Profile.
To provide a more natural and intuitive experience, Celigo Ora for filter rules allows you to engage naturally and conversationally. Instead of relying on a rigid and command-based approach, Ora will allow you to ask dynamic follow-up prompts with guided responses.
To maintain the defined scope, if your prompt/query falls outside the assistant’s capabilities, Ora will display an error message or guide you with relevant information.
Create filter rules from simple language prompts
To create a filter, enter a valid prompt in Celigo Ora. After the results of your initial prompt are retrieved, you can enter additional prompts that describe additional changes to the expression that Ora might not have fully understood. All previously provided prompts will be saved and can be viewed or copied. The editor also provides sample text to inform your use of the text prompt field.
Click thumbs up or thumbs down for each prompt to indicate if the response provided by Ora was helpful or unhelpful.
Example 1: A simple example with two prompts
Sample JSON Prompt Filter Rule
    "record": {
      "name": "John",
      "age": 30
Only process where name is John and age is greater than 21
23502889721115-bb6cd204-c423-4944-a89e-55594693ef46
Example 2: A prompt with complex query and grouping operation
    "record": {
      "id": 1,
      "title": "iPhone 9",
      "description": "An apple
mobile which is nothing
like apple",
      "price": 549,
      "discountPercentage": 12.96,
      "rating": 4.69,
      "stock": 94,
      "brand": "Apple",
      "category": "smartphones"
    "settings": {
      "integration": {},
      "flow": {},
      "flowGrouping": {},
      "connection": {},
      "iClient": {},
      "export": {}
"filter based on following conditions 1. samsung brand, 3.9 rating, smartphones category or 2. apple brand, 4 rating, wearables category"
23502889730203-4e3f121d-97cd-4849-9121-aa380f563922
Example 3: A complex prompt with numbers
    "record": {
      "listingId": 8391,
      "make": "Tesla",
      "model": "Model Y",
      "year": 2022,
      "price": 49999,
      "mileage": 5000,
      "color": "Midnight
Silver Metallic",
      "interior": "Black",
      "battery": "Long Range",
      "range": 326,
      "status": "available",
      "location": {
        "city": "Los Angeles",
        "state": "CA"
filter based on below conditions 1. made by either Tesla or Toyota 2. year should be between 2020 and 2022 3. status is available 4 price is less than 60000
23502889735579-b9dccc8c-2b86-4298-963a-7fb75b963940
Example 4: An example to create filter rules for settings
  "record": {
    "product": "Laptop",
    "brand": "Dell",
    "model": "XPS 15",
    "price": 1200,
    "inStock": true
  "settings": {
    "integration": {
      "name": "sales"
    "flow": {
      "environment": "sandbox"
    "flowGrouping": {},
    "connection": {},
    "iClient": {},
    "export": {}
filter by following rules i. should be in stock item i. integration name is "sales" iii. environment is "sandbox"
23502889742875-39409a67-002c-4078-a0f2-a5a450f968bd
Explain filter rules in simple language
Ora explains the filter options for the rules configured. Say Explain filter rules to generate a detailed explanation for the filter rule. You can reposition the explanation window as needed.
When explaining filter rules, if the rule includes a negative operation and you select "not equal" in the Rules editor, Ora may not generate accurate results.
Sample JSON Prompt Explanation
    "record": {
      "name": "John",
      "age": 30
The filter rule is an "and" condition, meaning both conditions must be true for the filter to pass.
- The first condition checks if the name extracted from the data is equal to "John".
- The second condition checks if the age extracted from the data is greater than 21.
    "record": {
      "id": 1,
like apple",
      "price": 549,
      "rating": 4.69,
      "stock": 94,
      "brand": "Apple",
    "settings": {
      "integration": {},
      "flow": {},
      "flowGrouping": {},
      "connection": {},
      "iClient": {},
      "export": {}
The filter rules can be explained as follows:
1. If the brand is "samsung" and the rating is 3.9 and the category is "smartphones", OR
2. If the brand is "apple" and the rating is 4 and the category is "wearables".
    "record": {
      "listingId": 8391,
      "make": "Tesla",
      "model": "Model Y",
      "year": 2022,
      "price": 49999,
      "mileage": 5000,
      "color": "Midnight
Silver Metallic",
      "range": 326,
      "location": {
        "state": "CA"
The filter rule can be explained as follows:
- The rule contains multiple conditions that are connected using the "and" operator.
- The first condition is an "or" condition, which means either of the following conditions can be true:
- The value of the "make" field is equal to "Tesla".
- The value of the "make" field is equal to "Toyota".
- The second condition is that the value of the "year" field is greater than or equal to 2020.
- The third condition is that the value of the "year" field is less than or equal to 2022.
- The fourth condition is that the value of the "status" field is equal to "available".
- The fifth condition is that the value of the "price" field is less than 60000.
  "record": {
    "brand": "Dell",
    "model": "XPS 15",
    "price": 1200,
    "inStock": true
  "settings": {
    "integration": {
      "name": "sales"
    "flow": {
    "flowGrouping": {},
    "connection": {},
    "iClient": {},
    "export": {}
The filter rule is an "and" condition, meaning all the conditions must be true for the filter to pass.
Explanation of each condition:
1. Check if the value of the field "inStock" is equal to true.
2. Check if the value of the field "integration.name" is equal to "sales".
3. Check if the value of the field "integration.flow.environment" is equal to "sandbox".
All three conditions must be true for the filter to pass.
