When you configure an export, import, or other type of flow step using the prebuilt Microsoft Power BI connector, you can select any of the API operations listed below*, organized by API type.
If your API endpoint isn’t listed here, switch the flow step to HTTP mode and configure the endpoint provided in the Microsoft Power BI API documentation. *You can also create a composite endpoint for this application in HTTP mode.
Resource |
API endpoint |
Export |
Import |
Admin |
Dashboards: Get dashboards as admin |
X |
Dashboards: Get dashboards in group as admin |
X |
Dashboards: Get tiles as admin |
X |
Datasets: Get datasets as admin |
X |
Datasets: Get datasets in group as admin |
X |
Datasets: Get data sources as admin |
X |
Groups: Get groups as admin |
X |
Imports: Get imports as admin |
X |
Reports: Get reports as admin |
X |
Reports: Get reports in group as admin |
X |
Available features |
Get available features by name |
X |
Get available features |
X |
Capacities |
Get capacities |
X |
Groups: Assign my workspace to capacity |
X |
Groups: Assign to capacity |
X |
Dashboards |
Get dashboard |
X |
Get dashboard in group |
X |
Get dashboards |
X |
Get dashboards in group |
X |
Get tile |
X |
Get tile in group |
X |
Get tiles |
X |
Get tiles in group |
X |
Add dashboard |
X |
Add dashboard in group |
X |
Clone tile |
X |
Clone tile in group |
X |
Datasets |
Get dataset by ID |
X |
Get dataset by ID in group |
X |
Get datasets |
X |
Get datasets in group |
X |
Get data sources |
X |
Get data sources in group |
X |
Get gateway data sources in group |
X |
Get parameters |
X |
Get parameters in group |
X |
Get refresh history |
X |
Get refresh history in group |
X |
Delete dataset by ID |
X |
Delete dataset by ID in group |
X |
Refresh dataset |
X |
Refresh dataset in group |
X |
Set all dataset connections |
X |
Set all dataset connections in group |
X |
Take over in group |
X |
Update data sources |
X |
Update data sources in group |
X |
Update parameters |
X |
Update parameters in group |
X |
Gateways |
Get data source by ID |
X |
Get data source status by ID |
X |
Get data source users |
X |
Get data sources |
X |
Get gateway by ID |
X |
Get gateways |
X |
Add data source user |
X |
Delete data source |
X |
Delete datasource user |
X |
Group |
Get group users |
X |
Get groups |
X |
Add group user |
X |
Create group |
X |
Delete group |
X |
Delete user in group |
X |
Imports |
Get import by ID |
X |
Get import by ID in group |
X |
Get imports |
X |
Get imports in group |
X |
Create temporary upload location |
X |
Create temporary upload location in group |
X |
Push datasets |
Datasets: Get tables |
X |
Datasets: Get tables in group |
X |
Datasets: Post dataset |
X |
Datasets: Post dataset in group |
X |
Datasets: Post rows |
X |
Datasets: Post rows in group |
X |
Datasets: Delete rows |
X |
Datasets: Delete rows in group |
X |
Datasets: Put table in group |
X |
Datasets: Put table |
X |
Callouts |
Groups: Delete user as admin |
X |
Embed token |
Dashboards: Generate token in group |
X |
Datasets: Generate token in group |
X |
Reports: Generate token for create in group |
X |
Reports: Generate token in group |
X |
X |
Reports |
Rebind report |
X |
Rebind report in group |
X |
Clone report |
X |
Clone report in group |
X |
Delete report |
X |
X |
Update report content |
X |
Update report content in group |
X |
Export report |
X |
Get report |
X |
Get report in group |
X |
Get reports |
X |
Get reports in group |
X |
