Benchling is a cloud-based platform designed to streamline life science research and development, offering tools for experiment planning, data analysis, and collaboration enabling scientists to accelerate discoveries and optimize workflows in areas such as biotechnology, pharmaceuticals, and genomics.
Tenant name * |
Enter your Benchling tenant ID. For example, if your URL is |
Auth type * |
Select your Benchling account authentication type (either Basic or Token). |
Auth type: Basic |
API key * |
Enter your Benchling API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the |
Auth type: Token |
Client ID * |
Enter your Benchling client ID. |
Client secret * |
Enter your Benchling client secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your client secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 2.0 auth and token universal connector documentation respectively.
Sign in to your Benchling account.
Navigate to your Avatar > Settings > API > Keys .
Click Generate new API key .
Copy the API key .
Navigate to User menu > Developer console > Apps .
Click Create .
Enter a Name and Description.
Copy the Client ID .
Click Generate secret.
Copy the Client secret.
