Auto-map destination fields using Celigo AI
Auto-map allows you to use Celigo AI prompts to populate source and destination field mappings. Auto-map applies to mappings that use string, number, boolean, array, object, object arrays, and input fields. You must have at least one row with a value in a destination field to auto-map with Celigo AI.
  • This feature only applies to Mapper 2.0.
  • To auto-populate mappings, you must enable Celigo AI in your integrator.io account. Click the avatar in the upper right corner of integrator.io, click Profile, and check Enable AI chatbot .
Auto map all fields
You can auto-map all fields within the provided data using a prompt through Celigo AI.
Before
Result
Celigo AI prompt: I need to auto map all fields
Auto-map doesn’t overwrite mapping values that have already been entered manually. For example, if the destination fields already have the values: studentName, studentAge, and marks, and you enter the prompt, “I need to auto-map all fields,” then auto-map will preserve the manually entered fields and only add field mappings for the remaining destination fields.
Before
Result
Auto map required fields
You can auto-map only required fields. Required field names are non-editable.
Before
Result
Celigo AI prompt: I need to auto-map all required fields
22084605703579-37eacf97-d558-428f-812f-11bc4129290a
22084605709595-4b04b183-adb4-4923-a991-1e6d81c70286
Auto map specified fields
For more targeted mapping, you can provide the exact names of one or more required fields in your prompt and auto-map only those fields. Use serial commas in plain English to separate each field name in your prompt.
Before
Result
Celigo AIprompt: I need to auto map studentName, studentAge, and marks
22084605712667-18d12126-71ba-4faf-bc29-e0d52f805bfa
22084605714715-a95f4111-f17b-49f9-8b71-a19c03fe376c
Was this article helpful?
0 out of 0 found this helpful
