Auto-map allows you to use Celigo Ora prompts to populate source and destination field mappings. Auto-map applies to mappings that use string, number, boolean, array, object, object arrays, and input fields. You must have at least one row with a value in a destination field to auto-map with Celigo Ora.
This feature only applies to Mapper 2.0.
To auto-populate mappings, you must enable Celigo Ora in your integrator.io account. Click the avatar in the upper right corner of integrator.io, click My Profile, and check Ora .
You can auto-map all fields within the provided data using a prompt through Celigo Ora.
Before |
Result |
Celigo AI prompt: I need to auto map all fields |
Auto-map doesn’t overwrite mapping values that have already been entered manually. For example, if the destination fields already have the values: studentName, studentAge, and marks, and you enter the prompt, “I need to auto-map all fields,” then auto-map will preserve the manually entered fields and only add field mappings for the remaining destination fields.
Before |
Result |
Celigo Ora prompt: I need to auto map all fields |
You can auto-map only required fields. Required field names are non-editable.
Before |
Result |
Celigo Ora prompt: I need to auto-map all required fields |
For more targeted mapping, you can provide the exact names of one or more required fields in your prompt and auto-map only those fields. Use serial commas in plain English to separate each field name in your prompt.
Before |
Result |
Celigo Oraprompt: I need to auto map studentName, studentAge, and marks |
