Customer.io is a customer communication platform facilitating personalized messaging and automation, empowering businesses to engage with their audience at scale.
API type * |
Choose your Customer.io account API type:
API type: Data pipelines |
API key * |
Enter your Customer.io API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
API type: Journeys track |
API key * |
Site ID * |
Enter your Customer.io site ID. |
API type: Journeys app |
Environment * |
Select your Customer.io account environment region (either EU or US). |
API key * |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom, basic, and token universal connector documentation.
Sign in to your Customer.io account.
From the left panel, navigate to Data pipelines > Sources.
Select a source. For more information, see Data pipelines.
Navigate to Settings > API keys.
Click Create API key.
Copy the API key.
Navigate to Settings > Account settings > API credentials.
Click Track API keys.
Click Create track API key.
Enter a Name and select a Workspace.
Copy the API key.
Copy the Site ID.
Click Create app API key.
Copy the API key.
