Available Oracle Eloqua Automation APIs
When you configure an export, import, or other type of flow step using the prebuilt Oracle Eloqua connector, you can select any of the API operations listed below, organized by API type.
Note: If your API endpoint isn’t listed here, switch the flow step to HTTP mode and configure the endpoint provided in the Oracle Eloqua API documentation. You can also create a composite endpoint for this application in HTTP mode.
Resource API endpoint Export Import
Activities Retrieve a list of activities X
Landing pages Create a landing page   X
Retrieve a landing page X
Update a landing page   X
Delete a landing page   X
Retrieve a list of landing pages X
Images Retrieve an image X
Update an image   X
Delete an image   X
Upload an image   X
Retrieve a list of images X
Forms Create a form   X
Retrieve a form X
Update a form   X
Delete a form   X
Retrieve a list of forms X
SMS keywords Retrieve a list of keywords X
Retrieves a keyword X
Create a keyword   X
Deletes a keyword   X
Email folders Create an email folder   X
Retrieve an email folder X
Update an email folder   X
Delete an email folder   X
Retrieve a list of email folders X
Emails Create an email   X
Retrieve an email X
Update an email   X
Delete an email   X
Retrieve a list of emails X
Email headers Create an email header   X
Retrieve an email header X
Update an email header   X
Delete an email header   X
Retrieve a list of email headers X
Email groups Create an email group   X
Retrieve an email group X
Update an email group   X
Delete an email group   X
Retrieve a list of email groups X
Email footers Create an email footer   X
Retrieve an email footer X
Update an email footer   X
Delete an email footer   X
Retrieve a list of email footers X
Custom objects Create a custom object   X
Retrieve a custom object X
Update a custom object   X
Delete a custom object   X
Retrieve a list of custom objects X
Content sections Create a content section   X
Retrieve a content section X
Update a content section   X
Delete a content section   X
Retrieve a list of content sections X
Contact fields Retrieve a contact field X
Update a contact field   X
Delete a contact field   X
Create a contact field   X
Retrieve a list of contact fields X
Contact segments Create a contact segment   X
Retrieve a contact segment X
Update a contact segment   X
Delete a contact segment   X
Retrieve a list of contact segments X
Contact list Create a contact list   X
Retrieve a contact list X
Update a contact list   X
Delete a contact list   X
Retrieve a list of contact lists X
Users Create a user   X
Retrieve a user X
Update a user   X
Delete a user   X
Retrieve the current user X
Update a user's password   X
Enable or disable a user   X
Retrieve a list of users X
Security groups Create a security group   X
Retrieve a security group X
Update a security group   X
Delete a security group   X
Retrieve security groups X
Add or remove users from a security group   X
Audit logs Initiate an audit log export   X
SMS folders Create a folder   X
Retrieves a folder X
Update a folder   X
Deletes a folder   X
Retrieve a list of folder contents X
Add content to a folder   X
Retrieve the root folder X
Retrieve a list of folder contents in the root folder X
Retrieve a list of subfolders in the root folder X
Retrieve a list of subfolders X
Retrieve a list of folders X
SMS Retrieve a list of SMS X
Create a SMS   X
Retrieves a SMS X
Update a SMS   X
Deletes a SMS   X
Email deployment Create and send an email deployment   X
Retrieve an email deployment X
Email folders Create a folder   X
Retrieve a folder X
Update a folder   X
Delete a folder   X
Retrieve an email X
Update an email   X
Delete an email   X
Archive an email   X
Unarchive an email   X
Accounts Retrieve account group membership information for an account X
Retrieve account information   X
Retrieve a list of account export definitions X
Create an account export definition   X
Retrieve an account export definition X
Update an account export definition   X
Delete an account export definition   X
Retrieve an account export definition's synced data X
Delete an account export definition's data   X
Retrieve an account field definition X
Retrieve a list of account field definitions X
Retrieve a list of account import definitions X
Create an account import definition   X
Retrieve an account import definition X
Update an account import definition   X
Delete an account import definition   X
Upload data for a specified account import definition   X
Delete an account import definition's data   X
Retrieve an account list definition X
Retrieve a list of account list definitions X
Retrieve a list of account sync action definitions X
Create an account sync action definition   X
Retrieve an account sync action definition X
Update an account sync action definition   X
Delete an account sync action definition   X
Upload account sync action data   X
Delete sync data for an account sync action definition   X
Contacts Retrieve a list of contact export definitions X
Create a contact export definition   X
Retrieve a contact export definition X
Update a contact export definition   X
Delete a contact export definition   X
Retrieve a contact export definition's synced data X
Delete a contact export definition's data   X
Retrieve a contact field definition X
Retrieve a list of contact field definitions X
Retrieve a contact filter X
Retrieve a list of contact filters X
Retrieve a list of contact import definitions X
Create a contact import definition   X
Retrieve a contact import definition X
Update a contact import definition   X
Delete a contact import definition   X
Upload data for a contact import definition   X
Delete a contact import definition's data   X
Retrieve a lead-scoring model X
Retrieve a list of lead-scoring models X
Retrieve a list of contact sync action definitions X
Create a contact sync action definition   X
Retrieve a contact sync action definition X
Update a contact sync action definition   X
Delete a contact sync action definition   X
Upload contact sync action data   X
Delete sync data for a contact sync action definition   X
Activities Retrieve a list of activity export definitions X
Create an activity export definition   X
Retrieve an activity export definition X
Update an activity export definition   X
Delete an activity export definition   X
Retrieve an activity export's synced data X
Delete an activity export definition's data   X
Retrieve an activity field definition X
Retrieve a list of activity field definitions X
Retrieve a list of activity import definitions X
Create an activity import definition   X
Retrieve an activity import definition X
Update an activity import definition   X
Delete an activity import definition   X
Upload data for a specified activity import definition   X
Delete an activity import definition's data   X
Dedupe rules Search for dedupe and match rules by name X
Get the dedupe rule handler sets X
Get handler set summary X
Get single dedupe or match rule X
External activities Create an external activity   X
Retrieve an external activity X
Custom objects Retrieve a custom object X
Retrieve a list of export definitions for a custom object X
Create an export definition for a custom object   X
Retrieve a list of the fields for a custom object X
Retrieve a list of import definitions for a custom object X
Create an import definition for a custom object   X
Retrieve a list of sync action definitions for a custom object X
Create a custom object sync action definition   X
Retrieve the specified export definition for a custom object X
Update an export definition for a custom object   X
Delete a custom object export definition   X
Retrieve the synced data for a custom object export definition X
Delete the synced data for a custom object export definition   X
Retrieve a custom object field definition X
Retrieve an import definition for a custom object X
Update an import definition for a custom object   X
Delete a custom object import definition   X
Upload data for a custom object import definition   X
Delete synced data for a custom object import definition   X
Retrieve a custom object sync action definition for a custom object X
Update a custom object sync action definition   X
Delete a custom object sync action definition   X
Upload custom object sync action data   X
Delete sync data for a custom object sync action definition   X
Visitors Retrieve visitor data X
Retrieve visitor data by visitor GUID   X
Sync actions Retrieve a list of sync action definitions X
Email addresses Retrieve a list of email address import definitions X
Create an email address import definition   X
Retrieve an email address import definition X
Update an email address import definition   X
Delete an email address import definition   X
Submit data for an email address import   X
Delete an email address import definition's synced data   X
Event registrants Create an event registrant   X
Retrieve an event registrant X
Update an event registrant   X
Delete an event registrant   X
Retrieve a list of event registrants X
Custom object data Create custom object data   X
Retrieve custom object data X
Update custom object data   X
Delete custom object data   X
Retrieve a list of custom object data X
Syncs Retrieve a list of syncs X
Create an import or export sync   X
Retrieve a sync X
Retrieve an export sync's data X
Delete sync data   X
Retrieve a sync's logs X
Retrieve import sync failure data X
Email groups Retrieve an email group X
Form data Retrieve processed form data for a single form X
Create form data for a single form   X
Delete form data   X
Retrieve a single form submit job X
Retrieve all form submit jobs for a single form X
Retrieve all spam form submit jobs for a single form X
Create form data in batch for a single form   X
Retrieve batch form submission details by batch ID X
Retrieve batch form submission details by batch correlation ID X
Contacts Retrieves a contact X
Update a contact   X
Retrieve contact list membership information for a contact X
Retrieve contact information   X
Imports Discover the amount of database space your imports are using X
Retrieve an import priority X
Retrieve a list of import priorities X
Retrieve a list of imports X
Image folders Create a folder   X
Retrieve a folder X
Update a folder   X
Delete a folder   X
Hyperlink folders Create a folder   X
Retrieve a folder X
Update a folder   X
Delete a folder   X
SMS subscription Update a subscription   X
Retrieve a list of subscriptions   X
Form folders Create a folder   X
Retrieve a folder X
Update a folder   X
Delete a folder   X
Retrieve a form X
Update a form   X
Delete a form   X
Partially update a form   X
Archive a form   X
Unarchive a form   X
Events Create an event   X
Retrieve an event X
Update an event   X
Delete an event   X
Retrieve a list of events X
Retrieve an event X
Retrieve a list of export definitions for an event X
Retrieve a list of the fields for an event X
Retrieve a list of import definitions for an event X
Create an export definition for an event   X
Retrieve an export definition for an event X
Update an export definition for an event   X
Delete an export definition for an event   X
Retrieve the synced data for an event export definition X
Delete the synced data for an event export definition   X
Retrieve an event field definition X
Create an import definition for an event   X
Retrieve an import definition for an event X
Update an import definition for an event   X
Delete an import definition for an event   X
Upload data for an event import definition   X
Delete the synced data for an event import definition   X
External assets Create an external asset   X
Retrieve an external asset X
Update an external asset   X
Delete an external asset   X
Retrieve a list of external assets X
Exports Discover the amount of database space your exports are using X
Retrieve a list of exports X
Campaign responses Retrieve a list of campaign response export definitions X
Create a campaign response export definition   X
Retrieve a campaign response export definition X
Update a campaign response export definition   X
Delete a campaign response export definition   X
Retrieve the synced data for a campaign response export definition X
Delete the synced data for a campaign response export definition   X
Retrieve a campaign response field definition X
Retrieve all campaign response fields X
Retrieve a list of campaign response import definitions X
Create a campaign response import definition   X
Retrieve a campaign response import definition X
Update a campaign response import definition   X
Delete a campaign response import definition   X
Upload data for a campaign response import definition   X
Delete the synced data for a campaign response import definition   X
Campaigns Retrieve a campaign field definition X
Retrieve a list of campaign fields X
Create a campaign   X
Retrieve a campaign X
Update a campaign   X
Delete a campaign   X
Activate a campaign   X
Deactivate a campaign   X
Retrieve a list of campaigns X
External asset types Create an external asset type   X
Retrieve an external asset type X
Update an external asset type   X
Delete an external asset type   X
Retrieve a list of external asset types X
Visitor profile fields Retrieve a list of visitor profile fields X
Opportunities Retrieve a list of opportunity contact linkage import definitions X
Create an opportunity contact linkage import definition   X
Retrieve an opportunity contact linkage import definition X
Update an opportunity contact linkage import definition   X
Delete an opportunity contact linkage import definition   X
Upload data for an opportunity contact linkage import definition   X
Delete the synced data for an opportunity contact linkage import definition   X
Retrieve an opportunity field definition X
Retrieve a list of opportunity fields X
Retrieve a list of opportunity import definitions X
Create an opportunity import definition   X
Retrieve an opportunity import definition X
Update an opportunity import definition   X
Delete an opportunity import definition   X
Upload data for an opportunity import definition   X
Delete the synced data for an opportunity import definition   X
Phone numbers Retrieve a list of phone number import definitions X
Create a phone number import definition   X
Retrieve a phone number import definition X
Update a phone number import definition   X
Delete a phone number import definition   X
Upload data for a specified phone number import definition   X
Delete a phone number import definition's data   X
Programs Create a program   X
Retrieve a program X
Update a program   X
Delete a program   X
Activate a program   X
Deactivate a program   X
Pause a program   X
Retrieve a list of programs X
Create a copy of a contact segment   X
SMS codes Retrieve a list of sender codes X
Users Retrieve a user X
Update a user   X
Contacts Create a contact   X
Retrieve a contact X
Update a contact   X
Delete a contact   X
Retrieve a list of contacts X
Accounts Create an account   X
Retrieve an account X
Update an account   X
Delete an account   X
Retrieve a list of accounts X
Option lists Retrieve an option list X
Update an option list   X
Delete an option list   X
Retrieve a list of option lists X
Create an option list   X
Microsites Create a microsite   X
Retrieve a microsite X
Update a microsite   X
Delete a microsite   X
Retrieve a list of microsites X
Campaign fields Create a campaign field   X
Retrieve a campaign field X
Update a campaign field   X
Delete a campaign field   X
Campaign folders Create a folder   X
Retrieve a folder X
Update a folder   X
Delete a folder   X
Account groups Create an account group   X
Retrieve an account group X
Update an account group   X
Delete an account group   X
Retrieve a list of account groups X
Lookup tables Retrieve a lookup table X
Search for a lookup table by name field X
Search for lookup table entries by lookup or replacement field X
Update existing lookup table entry   X
Delete lookup table entry by ID   X
Add lookup table entry for an existing lookup table   X
Custom object data Retrieve a list of custom object data X
SMS invalid keyword messages
Retrieve a list of messages
X
Retrieves a message X
Update a message   X
Deletes a message   X
Create a message   X
