Deel is a comprehensive platform that simplifies global hiring and payroll processes for remote teams, offering streamlined solutions for contracts, payments, and compliance.
Environment * |
Select your Deel account environment type:
Auth type * |
Select your Deel account authentication type (either OAuth 2.0 or token). |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Deel. How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit () button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource |
Token * |
Enter your Deel API token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Scopes * |
Scopes are OAuth 2.0 permissions that Deel defines to limit access to your account. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 2.0, universal connector documentation.
