AdRoll is a leading digital marketing platform that specializes in retargeting and personalized advertising campaigns across multiple channels.
Auth type * |
Select your AdRoll account authentication type (either OAuth 2.0 or Token). |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by AdRoll. How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Token * |
Enter your AdRoll API token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
API key * |
Enter your AdRoll API key (client ID). |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the OAuth 2.0, universal connector documentation.
Sign in to your AdRoll developer account.
Navigate to Applications.
Select the required application. For detailed information on how to create an app, see Get started.
Copy the Client ID/API key.
Copy the Client secret.
Navigate to Dashboard > Settings.
Click Create token. For detailed information on how to create an app, see Get started.
Copy the Token.
