Set up a connection to Airtable
Airtable is a versatile collaboration platform that combines the flexibility of a spreadsheet with the power of a database, enabling teams to organize, track, and manage projects and workflows in a customizable and intuitive manner.
Setting
Instructions
Name your connection *
API type *
Choose your Airtable account API type:
REST:  Create, read, update, and delete operations on records, manage tables, and query data
SCIM: Retrieve, add, and modify users and groups
Auth type *
Select your Airtable account authentication type (either OAuth 2.0 or Token).
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Airtable.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
Token *
Enter your Airtable token.
How to retrieve the token
Scopes *
Scopes are OAuth 2.0 permissions that Airtable defines to limit access to your account.
How to configure scopes
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 2.0, and token universal connector documentation.
  1. Sign in to your Airtable account.
  2. Navigate to Profile > Developer hub > Developers > OAuth integrations.
  3. Click + Register new OAuth integration.
  4. Enter a Name.
  5. Enter the integrator.io Redirect URL.
  6. Click Register integration.
  7. Navigate to Developer details.
  8. Check the Scopes.
  9. Copy the Client ID.
  10. Copy the Client secret.
  2. Navigate to Profile > Developer hub > Developers > Personal access tokens.
  3. Click + Create new token.
  4. Enter a Name.
  5. Add the Scopes.
  6. Click Create token.
  7. Copy the Token.
  1. Click Scope.
    – or –
  3. Click Save.
