Codility is a technical hiring platform that helps organizations assess and evaluate the coding skills of software developers.
Auth type * |
Select your Codility account authentication type (either OAuth 2.0 or Token). |
Auth type: Token |
API key * |
Enter your Codility API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Auth type: OAuth 2.0 |
Client ID* |
Enter your Codility client ID. |
Client secret * |
Enter your Codility client secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your client secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Token and OAuth 2.0 universal connector documentation respectively.
Sign in to your Codility account.
Navigate to My account > Settings > Integrations > Custom integrations > Create app.
Click Create app. For more information, see Authentication.
Enter an Application name.
Click Create.
Copy the API key.
Copy the Client ID.
Copy the Client secret.
