DHL is a global logistics and shipping company renowned for its extensive network and reliable delivery services, catering to businesses and individuals worldwide.
| Setting | Instructions |
| Name your connection * |
| API type * |
Choose your DHL API type:
| DHL eCommerce Europe API type | |
| Environment * |
Select your DHL account environment:
| OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by DHL. For information on retrieving the client ID and client secret, see User Guide. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
| DHL Express Global API type | |
| Environment * |
Select your DHL Express Global environment:
| DHL Parcel API type | |
| User ID * | Enter your DHL Parcel user ID. For more information on retrieving and using your user ID, see Using the API. |
| Key * | Enter your DHL Parcel key. For more information on retrieving and using your key, see Using the API. |
| Account numbers | Enter your DHL Parcel account number. |
| Auth type * | Select your DHL account authentication type (either Basic or Token). |
| Auth type: Basic | |
| Username * | Enter your DHL account username. |
| Password * |
Enter your DHL account password. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
| Auth type: Token | |
| Token * |
Enter your DHL account token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 2.0 universal connector documentation.
