Typeform is an interactive online form and survey platform that enables users to create engaging and conversational forms, surveys, and quizzes.
Auth type * |
Select your Typeform account authentication type (Token or OAuth 2.0). |
Token * |
Enter your Typeform token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Typeform How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 2.0, universal connector documentation.
Sign in to your Typeform account.
Navigate to Profile > Account > Your settings > Personal tokens.
Click Generate a new token.
Enter a Token name and select the Scopes.
Click Generate token.
Copy the Token.
Navigate to your Organization > Developer apps.
Click Register a new app.
Enter an App name.
Enter the App website.
Enter the Celigo integrator.io Redirect URI.
Enter Developer email.
Click Register app.
Copy the Client ID.
Copy the Client secret.
