Set up a connection to Podio
Podio is a versatile project management and collaboration platform that allows teams to customize workflows, manage tasks, and communicate effectively.
Setting
Instructions
Name your connection *
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Podio.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource
Grant type *
Select your OAuth 2.0 grant type (either Authorization code or Password credentials)
Username *
Enter your Podio account username.
Password *
Enter your Podio account password.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 2.0, universal connector documentation.
  1. Sign in to your Podio account.
  2. Open the Podio API document and navigate to Get an API key.
  3. Click Get an API key now.
  4. Enter an Application name.
  5. Enter the Celigo full domain (integrator.io).
  6. Click Generate API key.
  7. Copy the Client ID.
  8. Copy the Client secret.
Additional references
