Contentful is a cloud-based content management system (CMS) designed to help organizations create, manage, and deliver digital content across various platforms and channels.
API type * |
Choose your Contentful API type:
Region * |
Select your Contentful account region (either EU or Non-EU). |
Space ID * (for content delivery API type) |
Enter your Contentful space ID. |
CDA access token * (for content delivery API type) |
Enter your Contentful CDA access token. Multiple layers of protection, including AES 256 encryption, are in place to keep your CDA token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
CPA access token * (for content preview and SCIM API types) |
Enter your Contentful CPA access token. Multiple layers of protection, including AES 256 encryption, are in place to keep your CPA token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
CMA access token * (for content user management API type) |
Enter your Contentful CMA access token. Multiple layers of protection, including AES 256 encryption, are in place to keep your CMA token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Organization ID * (for content SCIM and user management API types) |
Enter your Contentful organization ID. |
Sign in to your Contentful account.
Navigate to Settings > API keys.
Click + Add API key.
Enter a Name.
Click Add API key.
Copy the Space ID.
Copy the CDA access token.
Copy the CPA access token.
Navigate to Settings > CMA tokens.
Click + Create personal access token.
Enter a Token name and select Expiration date.
Click Generate.
Copy the Personal access token.
Click the Contentful icon in the top left corner.
Click Organization.
Click + Create organization.
Enter a Name.
Click Create organization.
Copy the Organization ID.
