ConnectWise is a suite of software solutions designed for IT service providers and managed service providers (MSPs)
Region * |
Select your ConnectWise account region (either AU, EU, or NA). |
Client ID * |
Enter your ConnectWise client ID. |
Username * |
Enter your ConnectWise company ID followed by + and public key. |
Password * |
Enter your ConnectWise private key. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Basic auth universal connector documentation.
Sign in to your ConnectWise account.
Click Create new integration.
Enter an Integration name and Description.
Choose Integration type and enter Technical contact email.
Select the Product.
Click Submit.
Copy the Client ID.
Navigate to Companies.
Copy the Company ID.
Navigate to My account > API keys.
Click +.
Copy the Public key.
Copy the Private key.
