Assembled is a modern workforce management platform built for rapidly scaling support teams. It helps to forecast support demand, build and manage team schedules, and uncover insights to improve your support operations.
API key * |
Enter your Assembled API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Assembled account.
Navigate to Company settings > API > API keys.
Click Create API key.
Enter a Name.
Click Create key.
Copy the API key.
Make sure to save your API key securely since it will not be displayed again.
