FedEx is a leading global logistics powerhouse, playing a critical role in international commerce by ensuring fast and secure shipping services.
This video demonstrates creating a FedEx connection.
Environment * |
Select your FedEx account environment:
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by FedEx. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit () button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 2.0 universal connector documentation.
Sign in to your FedEx developer account.
Navigate to Menu > My projects.
Click + Create a project.
Select an API access requirement.
Click Select for the required API.
Check the required APIs.
Click Next.
Enter a Project name.
Read and check the terms.
Click Create.
Click Okay.
Copy the API key (Client ID).
Copy the Secret key (Client secret).
