Nexudus is a workspace management platform designed to help coworking spaces, shared offices, and flex workspaces automate operations, billing, and member engagement.
The Nexudus connector is in BETA and may be subject to changes.
API type * |
Choose your Nexudus account API type:
Subdomain * (if API type is Public) |
Enter your Nexudus subdomain. For example, if your account URL is |
Username * |
Enter your Nexudus account username. |
Password * |
Enter your Nexudus account password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
Marketplace ID * |
Enter your Nexudus account marketplace ID. |
Auth type * (if API type is Rest) |
Select your Nexudus account authentication type (either Basic or Token). |
