NetSuite SuiteProjects Pro is a comprehensive professional services automation (PSA) solution designed to support project-based organizations throughout the entire project delivery lifecycle.
The NetSuite SuiteProjects Pro connector is in BETA and may be subject to changes.
For SOAP API integration, you must enable the API access in NetSuite SuiteProjects Pro to get the API name and API namespace. For detailed information, seeEnabling API access.
API type * |
Choose your NetSuite SuiteProject Pro account API type:
Company ID * |
Enter your NetSuite SuiteProjects Pro company ID. For example, if your account URL is |
Environment * |
Select your NetSuite SuiteProjects Pro account environment (either Production or Sandbox). |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by NetSuite SuiteProjects Pro. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
API namespace * (applicable only for XML API type) |
Enter your NetSuite SuiteProjects Pro API namespace. |
API key * (applicable only for XML API type) |
Enter your NetSuite SuiteProjects Pro API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign into your NetSuite SuiteProjects Pro admin account.
Navigate to Administration > Global settings > Account > API integration applications.
Click Add new app.
Enter an Application name.
Enter Celigo Redirect URL.
Click Save.
Copy the Client ID.
Copy the Client secret.
