Unlock CashApp transaction body field
There’s no straightforward way to unlock this field as it is locked from the bundle. Hence it can only be unlocked from the bundle.
The latest version of Celigo CashApp Manager (40598) bundle has this field unlocked.
Steps to update the Celigo CashApp Manager (40598) bundle:
  1. Search for the below files in your NetSuite account and download them as a backup. When you update the bundle, these script files are updated.
    If there are any changes made to these files after the bundle is installed for the first time, the changes are lost upon bundle installation.
    1. Celigo.build.Lockbox.v2.js
    2. Celigo.products.lockbox.userevent.BatchUserEventHandler.js
    3. Celigo.products.lockbox.usereventTransactionUserEventHandler.js
    4. Celigo.products.lockbox.userevent.CreditMemoUserEventHandler.js
    5. Celigo.products.lockbox.userevent.InvoiceUserEventHandler.js
  2. Update the bundle. Navigate to Customization > SuiteBundler > Search & Install Bundles > List. Search for the bundle with ID 40598. Under the settings, click on Update and confirm the install updates in the next page.
  3. Once the bundle is installed, replace the files with the downloaded files.
  4. Verify that the transaction body field is unlocked now. Go to Customization > Lists, Records, & Fields > Transaction Body fields and search for CashApp transaction field.
