ClickUp is a productivity and project management tool that helps teams and individuals organize tasks, manage workflows, and collaborate efficiently.
Auth type * |
Select your ClickUp account API type (OAuth 2.0 or Token). |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by ClickUp. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ()button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource |
Scopes * |
Scopes are OAuth 2.0 permissions that ClickUp defines to limit access to your account. |
Personal API token * |
Enter your ClickUp personal API token. Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the respective documentation for OAuth 2.0 auth and Token auth universal connectors.
Sign in to your ClickUp account.
Navigate to Profile > Settings > Apps.
Click + Create new app.
Enter an App name.
Enter Celigo Redirect URL.
Click Create App.
Copy the Client ID.
Copy the Client secret.
Navigate to Profile > Settings > Apps > API token.
Copy the API token.
