How to activate ended listing for an item on eBay?
The Listing Ended checkbox in the Celigo eBay Item Id Account Map record is used as the criteria to exclude or include the item from being selected by the Celigo eBay Inventory/ Kit Inventory Export Search and Celigo eBay Pricing Export Search saved search in NetSuite. When this checkbox is enabled, the saved searches will not consider the item for updating pricing or other item information.
You can manually uncheck this check box to activate the listing again on eBay. Once this checkbox is disabled and the NetSuite Item to eBay Item Add/Update integration flow is run, the connector will update the Celigo eBay Item Id Account Map record in NetSuite as follows:
  • When you relist an item, the EBAY LISTING ID field is updated with the new value.
  • The connector deletes the date and time value from the LISTING ENDED TIME field.
Was this article helpful?
1 out of 1 found this helpful
1 comment
Date Votes
