As Walmart is deprecating the “digital signature-based authentication” using the “consumer ID” and “secret key”. If you are using this authentication method, your API calls will not work after August 28th, 2019. To ensure your API calls continue to work, you must switch to the “OAuth based authentication” model. You will have to now re-authenticate your Walmart connection using Walmart’s Client ID and Client Secret. By adding Celigo as a solution provider on the Walmart Developer site, you can retrieve Client ID and Client Secret.
- After the v1.11.1 release, “your connection will go offline” and no integration flow will run to sync data between NetSuite and Walmart.
- Ensure to create generate the Client ID and Client Secret in the Production tab.
Provide access for individual columns as follows:
Column name |
Access Type |
Get Feeds |
View Only |
Content |
No Access |
Items |
Full Access |
Inventory |
Full Access |
Price |
Full Access |
Lag Time |
No Access |
Order |
Full Access |
Returns |
No Access |
Reports |
No Access |
