In the Amazon (FBA) warehouse there might be multiple reasons for a loss or damage of inventory. To account for the loss, adjustments are made to the inventory levels in the Amazon (FBA) warehouse daily.
With the FBA Inventory Adjustments add-on, you can make sure that the lost or damaged inventory is automatically accounted for using the "Amazon (FBA) inventory adjustment to NetSuite inventory adjustment" flow. You can manage your inventory and ensure all the adjustments are reported in NetSuite.
The “Amazon (FBA) Inventory Adjustments to NetSuite Inventory Adjustments” add-on flow allows you to manage, maintain, and track your available inventory levels in NetSuite. It also categorizes sellable vs damaged inventory based on the disposition given by Amazon. The flow automatically syncs Amazon (FBA) adjustment data to NetSuite.
The flow imports the inventory adjustment to NetSuite as per the scheduled time. In Amazon, a real-time FBA Inventory Adjustment report is generated no more than once every 30 minutes. Before you send another request, there should be a 30-minute time lag for Amazon to generate the updated version of the report.
The supported and unsupported items in this add-on:
Supported:
- Inventory
- Assembly
- Lot Numbered
- Serialized
- Alias
- Matrix
- Bin
- Inventory status enabled
Not Supported (NetSuite limitation):
- Kit
The flow fetches the Inventory Adjustment report from Amazon and creates the Inventory Adjustment record(s) in NetSuite as follows:
NetSuite supports a maximum of 1,000 lines per inventory adjustment record. If an adjustment report exceeds this limit, the flow creates multiple inventory adjustment records of up to 1,000 lines each.
To understand more about add-ons, refer to Understanding integration app add-ons.
Amazon categorizes inventory adjustments by quantity and reason code.
Understand key terms:
- (- or +): type (- or +) in the quantity column denotes whether an adjustment is an increase or decrease to the inventory level.
- Reason: describes the type of adjustment made.
- Disposition: denotes the inventory disposition that represents the physical state of a product (unit or units).
| Sample Inventory Adjustment report | ||||||||
| Adjusted-date | Transaction-item -id | fnsku | sku | Product -name | Fulfillment-center-id | Quantity | Reason | Disposition |
| 2019-07-31T00:00:00-07:00 | 9249864 | X001K0P99R | 83542-01-N | Wireless Headset | RIC2 | -1 | M | SELLABLE |
| 2019-07-31T00:00:00-07:00 | 92537164 | B00EA07B0I | 506007-N | Telephone Headset | RIC2 | 1 | F | SELLABLE |
| 2019-07-31T00:00:00-07:00 | 92500164 | B00EA07B0I | 506007-N | Telephone Headset | RIC2 | -1 | O | SELLABLE |
| 2019-07-29T00:00:00-07:00 | 9869952533 | B00O1ANTD0 | 201500-01-N | Headset Mono | FTW6 | -1 | O | WAREHOUSE_DAMAGED |
A single report can contain multiple entries for the same item, reason, disposition, or transaction item ID. The reason code and disposition indicate whether the inventory is sellable or damaged. Inventory may be classified as damaged for various reasons, including defective, customer-damaged, distributor-damaged, warehouse-damaged, carrier-damaged, or expired products, where applicable.
For more information about adjustment types, reason types, and reason descriptions, refer to Inventory adjustments.
You can install this add-on from the "Subscriptions" section of your Integration App. For more information on how to install add-ons, refer to Add-Ons.
Before you configure or install the add-ons, in NetSuite, add the “Adjust Inventory” permission to the native “Celigo eTail SmartConnectors” role or to any other appropriate custom role.
Configure and run the flow
- In integrator.io, click Amazon - NetSuite Integration App tile.
- Go to Settings > Integration flows > Inventory (FBA).
Configure basic settings
- Enable the Amazon (FBA) Inventory Adjustments to NetSuite Inventory Adjustments flow.
In the flow's Settings, check the Select a start date for this flow box to select a start date for this delta flow. There is no impact on the scheduled run time if you check this box.
Recommended: If you run this flow for the first time, check the Select a start date for this flow box to fetch historical adjustments. If you don't check this box, the flow will not run successfully. Refresh the page after you check this box.
- Click Save.
Configure advanced settings
Go to Settings > Inventory (FBA) > FBA Inventory. In the Import event types into NetSuite setting, enter event types that must be imported into NetSuite. Records of event types entered in this setting will be imported into NetSuite, and records of all other event types will be ignored. By default, the ‘Adjustments’ event type is added to this setting. You can add other event types based on your business requirements, separated by commas.
The event types entered in this setting must match the event types in the report.
- In the Define criteria to search the matching items in NetSuite field, define the lookup criteria to search the matching items in NetSuite.
Notice
By default, the lookup criteria match the NetSuite Item name (Name (internal)) with the SKU from Amazon and return only active items. For retry data containing multiple SKUs separated by \r\n, you can modify the Handlebars expression to search for a specific SKU.
Replace {{{MSKU}}} with:
{{{decodeURI (split (encodeURI MSKU) '%0D%0A' index)}}}
Replace index with the SKU position (1, 2, 3, and so on) to use for the lookup. The lookup then searches for the SKU at the specified index. If no match is found, only that record is not synced with NetSuite.
The steps to modify the Handlebars helper are as follows:
- Access the Define lookup criteria pane by clicking Filter next to the Define criteria to search the matching items in NetSuite setting.
- Replace
{{{MSKU}}}with{{{decodeURI (split (encodeURI MSKU) '%0D%0A' index)}}}in the Name (internal) filter, where index is the SKU number (1, 2, 3, and so on) to use as the default search option. - Click Save & close to update the lookup criteria.
The lookup criteria will now search for the SKU with the specified index. If the specified index is not found, only that record will not be synced with NetSuite.
- In the Specify the Item field's Field ID that matches the Amazon SKU field, specify the NetSuite field ID that matches the Amazon SKU. You can specify only one field ID.
In the Offset time to sync Amazon FBA inventory setting, enter the value in minutes to set the offset time to sync Amazon FBA inventory. The recommended value is 4320 (72 hours)but can be modified as needed.
If the start date for the flow is set as 08:00 AM 04th January, today’s date is 05:00 PM 07th January, and you entered the lag time as 4320, the inventory will be synced from 08:00 AM 01st January till 05:00 PM 04th January. You can adjust the recommended value of 4320 minutes (72 hours) as needed. Setting a higher value, such as 5760 minutes (96 hours), may cause existing inventory to sync again for the additional time period. Setting a lower value, such as 2880 minutes (48 hours), may cause records outside that time period to be skipped.
If you check the Select a start date for this flow box by clicking Settings next to the Amazon (FBA) Inventory Adjustments to NetSuite Inventory Adjustments flow, the option to select the date and time for syncing historical inventory will appear when you click Run.
The most important thing to remember is that the inventory will be synced from the adjusted start date & time (Selected date & time – Value entered in the Offset time to sync Amazon FBA inventory setting) to the adjusted end date & time (Current date & time – Value entered in the Offset time to sync Amazon FBA inventory setting).
Information only for existing flows: When you enter a value in this setting for the first time in this setting, if the flow was last run on 08:00 AM 04th January and you enter the value as 4320 (72 hours), the flow will run as scheduled for the next 3 days (08:00 AM 04th January to 08:00 AM 07th January) with no records being updated for this time period. If you run the flow on 09:00 AM 07th January, the inventory will be updated from 08:00 AM 04th January to 09:00 AM 04th January (09:00 AM 07th January - 4320 minutes = 09:00 AM 04th January).
Select the Auto-assign number to Lot Numbered/Serialized items box to automatically assign inventory numbers to the Lot Numbered/Serialized items in NetSuite.
- When increasing inventory, a unique 11-digit system-generated number is automatically assigned as the serial or lot number in the item's inventory details.
- When decreasing inventory, the quantity is deducted from the existing inventory at the specified location.
Enter a value in Add a prefix for Lot Numbered/Serialized items to add a prefix to the unique system-generated number when increasing inventory. This setting is optional and can be configured based on your business requirements.
Notice
<Prefix> + <11-digit system-generated unique number>.
- Click Save.
If you want to assign a default bin number to all the items, you can add a mapping.
| Export Field (HTTP) | Import Field (NetSuite) |
| <enter the bin number> | inventory[*].binNumber |
Adjust your locations
Recommended:
- Select separate warehouse locations to track sellable and damaged inventory. When inventory is damaged at an Amazon fulfillment center, the flow creates two adjustments: one to decrease inventory at the sellable location and another to increase inventory at the damaged inventory location.
- For bin items, you must enable Preferred (Per Location) for the location where negative inventory adjustments are tracked. Configure this setting in the Inventory item record under the Bin Numbers tab.
- Go to FBA Locations.
From the Select the FBA warehouse location for sellable inventory drop-down list, select the warehouse location to track your sellable inventory.
The location you choose here should match the location in the Select inventory location present in NetSuite advanced setting for the Amazon (FBA) Order to NetSuite Order flow.
- From the Select the FBA warehouse location for damaged inventory drop-down list, select the warehouse location to track your damaged inventory. If you do not select a warehouse location, the Inventory Adjustment record will contain records only for the sellable (disposition) inventory.
- Click Save.
Recommended: We recommend that you add an input filter in the “Amazon (FBA) Inventory Adjustments to NetSuite Inventory Adjustments” integration flow to sync records only for the 'Adjustments' event type and the country/fulfillment centers that you add to this input filter.
To know how to add input filters, see Add input filter for FBA inventory adjustments.
Resolve "bin required" errors on sellable records
The flow retrieves all inventory adjustments from a single Amazon report and imports them as one batch. If a record in the batch fails, subsequent records may fail with the same error, even if they are otherwise valid. For example, a bin required error may appear for a sellable inventory location that does not use bins when the error actually originates from another record in the batch for a location that requires bins, such as a damaged inventory location.
A bin is not required for inventory adjustments at a sellable location that does not use bins. If a bin-required error occurs, retry one affected sellable record. If the retry succeeds, the error likely originated from another record in the batch. Retry the remaining sellable records and process records for bin-managed locations, such as damaged inventory, separately.
In the flow’s field mappings, add an entry as follows:
Export Field (HTTP) Import Field (NetSuite) Select your appropriate Adjustment account number Adjustment Account (InternalId) - On the mappings window, click Save & Close.
- Run the Amazon (FBA) Inventory Adjustments to NetSuite Inventory Adjustments flow.
A new pop-up window opens to select a custom date to import previous FBA inventory adjustment reports.
- Click Run.
After you run the “Amazon (FBA) Inventory Adjustments to NetSuite Inventory Adjustments” flow, the flow creates inventory adjustment record(s) in NetSuite. Based on the configured flow’s mappings, the flow displays the following in the Adjustments section:
- quantity in the “Adjust Qty. By” column.
- inventory adjustment reason in the “Celigo Amazon Reason Code” column.
You can configure the “Amazon (FBA) Inventory Adjustments to NetSuite Inventory Adjustments” flow’s field mappings to display other inventory adjustment report fields such as “disposition” and “fulfillment-center-id” to NetSuite custom fields.
While processing each inventory adjustment record, if the item is not found in NetSuite with lookup criteria on item record, the Integration App now searches the “Celigo eTail item alias” custom record list using the item name. If a matching record is found using the item name, the integration app fetches the associated parent SKU and posts an adjustment line against the selected location.
If SKU is not present on the item record in NetSuite and SKU is present on the “Celigo eTail item alias” custom record, the flow adjusts the quantity of the linked parent item.
Select the “Item aliases are configured in NetSuite” box in Integration Flows > Order (FBA) > Advanced Settings. When you run the “Amazon (FBA) Order to NetSuite Order Add” flow, the integration app looks for the items with the error message “ITEM_NOT_FOUND”. The filtered items with error messages are further searched using the “Celigo eTail item alias” list using the item name. If the items are found using the item name, an itemID is mapped to those filtered items. An adjustment is created to the original item.
If the “Item aliases are configured in NetSuite” box is not selected, The integration app does not perform item searches by item name.
Related articles
