Set up a connection to Celigo integrator.io
Celigo integrator.io is an integration platform-as-a-service (iPaaS). The Celigo integration platform delivers everything a growing business needs to automate every business process across the organization.
After you start the connection, you have to configure it in the Create connection panel and must complete all of the required *authentication settings:
Setting Instructions
Name your connection *  Enter a clear and distinguishable name. Throughout Celigo integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account.
Region *
Choose your Celigo integrator.io account region.
Token *
Enter your Celigo integrator.io API token.
Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
How to retrieve the API token
  1. Sign in to your Celigo integrator.io account.
  2. Navigate to Resources > API tokens.
  3. Click Create API token. The Create API token panel appears.
  4. Enter the token Name.
  5. From Auto purge token, select the time after which the token should be automatically purged from the system.
  6. Select the required Scope, either Full access or Custom. For more information on API tokens, see Managing API tokens and My API basics.
Additional reference
