eBay is an e-commerce marketplace that enables businesses and individuals to buy and sell products through online auctions and fixed-price listings across a global customer base.
Verify that you are signed in to eBay as the account owner when setting up a connection.
API type * |
Choose your eBay API type:
Account type * |
Select your eBay account type: Sell
Finance
XML
API site ID * |
Select your eBay regional listing marketplace. |
API compatibility level |
Enter your eBay API schema version. For more information, see Versions. |
Select scopes based on your specific business needs. For finance-related use cases, choose scopes under the Finance API section. Select the appropriate scopes from the Other APIs section for other use cases. The scopes you select must align with the types of API access required for your application to function effectively.
