eBay documentation: API guide , Authentication
Verify that you are signed in to eBay as the account owner when setting up a connection.
Start establishing an HTTP connection to ebay in either of the following ways:
From the Resources menu, select Connections. Then, click + Create connection at the top right.
– or –
While working in a new or existing integration, you can add an application to a flow simply by clicking Add source or Add destination/lookup.
Cloud to connect to a publicly accessible server application
On-premise to connect to a server that is publicly inaccessible and has integrator.io agent installed on it
This article is concerned only with the settings needed for eBay connections. For complete field documentation, see Set up an OAuth 2.0 HTTP connection.
Configure HTTP headers: Leave the Name and Value fields blank.
Base URI: Enter the following value: https://apiz.ebay.com
Media type: Select JSON from the drop-down menu.
Success media type: Select JSON from the drop-down menu.
Error media type: Select JSON from the drop-down menu.
Enter the following values in the Configure auth section of the Create connection pane. Leave all fields not explicitly described in this section at their blank or default values.
Authentication type: Select OAuth 2.0 from the drop-down menu. The menu items switch to Oauth 2.0 authentication fields.
Grant type: Select Authorization code from the drop-down menu.
Callback URL: This field automatically defaults to https://integrator.io/connection/oauth2callback.
The callback URL must be added to the eBay developer account while configuring the HTTP connection. Use the following steps to set the redirect URI for the eBay developer account:
Log in to your eBay developer account.
From Home, navigate to Application Keys>User Token.
Select the eBay account for your environment (production or sandbox).
Click Get a Token from eBay via your Application.
Click + Add eBay Reditrect URL.
Enter the following values:
Display Title:
Integrator IO -
Your privacy policy URL:
https://integrator.io/connection/oauth2callback -
Your auth accepted URL:
Your auth declined URL:
Click Save.
iClient: Assuming you haven’t yet established an eBay iClient (token ID-secret pair), click the + button to create one . Enter an identifiable Name along with the Client ID and Client secret from your eBay account. Click Save & close to add the iClient to your integrator.io account and select it for this connection.
Authentication URL: Enter the following URL: https://auth.ebay.com/oauth2/authorize
Scopes: Enter the following value: https://api.ebay.com/oauth/api_scope/sell.finances
Access token URL (required): Enter the following value: https://api.ebay.com/identity/v1/oauth2/token
Client authentication: Use the drop-down menu to select Send as basic auth header.
Location (required): Select Header from the drop-down menu.
Header name: Verify this field has the word "Authorization" entered.
Scheme (required): Select Bearer from the drop-down menu.
Expand the How to test this connection? section.
Ping relative URI: Enter the following relative URI: /sell/finances/v1/transaction
Ping method: Select GET from the drop-down menu.
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the eBay connection.
Save & authorize – click to save the connection and exit the Create connection pane.
Cancel – click to exit without saving any new changes.
Enter your email and password and click Sign in.
Click Agree to establish the connection.
