Gorgias is a helpdesk and live chat application that is designed especially for e-Commerce stores.
This video demonstrates creating a Gorgias connection.
After you start the connection, configure it in the Create connection panel and complete all the required * authentication settings:
Username * |
Enter your Gorgias account username. |
API key * |
Enter your Gorgias API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Subdomain * |
Enter your Gorgias subdomain. For example, if |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Basic auth universal connector documentation.
Sign in to your Gorgias account.
Navigate to Settings > RESTAPI > API access and credentials > Password.
Copy the API key.
