JOOR helps to connect brands and retailers globally to deliver seamless digital wholesale management from connection to payment.
After you start the connection , configure it in the Create connection panel and complete all the required * authentication settings:
API version |
Select your JOOR account API version (either v2 or v4). |
Environment * (API version v2) |
Select your JOOR account environment: Production: if your JOOR account URL is Sandbox: if your JOOR account URL is |
API token * |
Enter your JOOR API token provided by JOOR support team. For information on how to request API token, see Request access. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text. |
API version: v4 |
Account ID * |
Enter your JOOR account ID. For example, |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by their support team. For more information, see Authentication. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Username * |
Enter your JOOR account username. |
Password * |
Enter your JOOR account password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text. |
Environment * (API version v4) |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom and OAuth universal connector documentation.
