Google Drive is a cloud-based storage service that allows users to store, share, and synchronize files across various devices.
API type * |
Choose your Google Drive API type:
Scopes * |
Scopes are OAuth 2.0 permissions that Google Drive defines to limit access to your account. |
Enable PGP cryptographic |
Enable and configure this setting if this connection will be used to transfer and encrypt/decrypt files using PGP. |
