Move a stand-alone flow out of an integration
You can create a flow in an integration, then move it back to Standalone flows.
- Click into your integration tile. Make sure you're on the Flows tab.
- Click the Actions ... icon for the flow you want to detach, then click Detach flow. Your flow will be removed from that integration and placed in the Standalone flows tile. You can always move it back if desired.
Move a flow into an integration
Conversely, you can create a stand-alone flow, then move it into an integration. You create stand-alone flows when you use the Flow Builder tool directly without creating the flow in an integration. These flows are placed in the Standalone flows tile on the Home page. To do so:
- In your integration tile details, click the Attach flow link.
- Choose the flow(s) to attach, then click Attach. The flows will automatically display in the Flows tab.
