Contents
Asynchronous APIs
Some APIs are asynchronous, meaning that they require you to check for status updates while the external API processes data to return for a given request. While the external API is processing a requested task, you can send the asynchronous API additional requests to check if the task has been completed. The asynchronous API responds to each request with a response that confirms that the task is still in progress until a final response confirms the task is complete. The results of the task are then delivered to integrator.io.
- integrator.io submits a request to the asynchronous API resource.
- The asynchronous API resource responds with a message that says the requested task has been started.
- integrator.io sends async helper requests at regular intervals to check the status of the task.
- While the asynchronous API resource processes the requested task, it also responds to each integrator.io async helper request with a message confirming that the task is still in progress until the task is done.
- Once the task is complete, the asynchronous API resource responds to the most recent integrator.io async helper request with a confirmation that the task is complete and delivers the results of the requested task.
Async helpers
An export or import flow step can use an integrator.io async helper to easily communicate with asynchronous APIs. If your target application requires you to check the status of in-progress requests, use an async helper to send status check requests and review the responses returned from the asynchronous API resource.
Note: You can’t create async helpers for sandbox accounts.
Async helper for export example
You send an API a request to export all orders placed within the past month, but retrieving the requested data to fulfill that request requires using the asynchronous API request/response pattern outlined above. You set up an async helper to send requests at regular intervals while the asynchronous API resource gathers the previous month’s orders. The final result of these requests confirms that the external API has finished processing last month’s orders, and can return the data required to fulfill the initial request.
Async helper for import example
You send an API a POST request to import a series of large image files to a resource for website publication, but the asynchronous API resource hosting the images might require significant time to ingest and process the image data during import. You set up an async helper to send requests at regular intervals and the asynchronous API resource responds with the processing status until the images are ingested and processed. The final response from the asynchronous API resource confirms that the API has finished processing the requested task and confirms the images are ready for publication.
Create an async helper
Use the following steps to enable and create an async helper for your flow step.
- In the Advanced section on the Create import/export (or Edit import/export) panel, check the Configure async helper checkbox.
- Click the + icon to create a new async helper. If you have already created an Async helper for this platform, you can select it from the drop-down list. Click the pencil icon to edit an existing async helper..
- Complete the following fields on the Create async helper page:
General
Name (required): Enter a name for the async helper that you are creating.
Configure how to check status
Status export (required): The export resource responsible for checking if the requested task is done.
Initial wait time: Enter the wait time in minutes. This is the length of time integrator.io waits before sending the first check status message to the asynchronous API. For example, if you enter the number "2", integrator.io waits for two minutes before sending the first async helper request to check if the requested task is done.
Poll wait time: Enter the wait time in minutes. This is the length of time integrator.io waits before sending subsequent poll requests. For example, if you enter the number "2", integrator.io sends a check status request every two minutes until the target application returns a message indicating that the requested task is done.
Status path (required): Enter the XML/JSON path where the In progress values, Done values, and Error Values appear in the response received. This path is applied to resources extracted from the Status Export. For example, FeedProcessingStatus.
In progress values (case sensitive): Enter the values returned by the asynchronous API that communicate that the requested task is still in progress and is not done yet. Consult the external API documentation to determine the values returned. For example, if you have sent an API request to Amazon, your in-progress values are: SUBMIT, IN PROGRESS. Use comma-separated values to define multiple in progress values.
Done values: Enter the values returned by the asynchronous API that communicate that the requested task is done. For example, for Amazon the value is “DONE”. Use comma-separated values to define multiple error values.
Done without data values: Enter the value(s) that you receive as a response from the target application after the feed processing is complete without data.
Error values (case sensitive): Enter the values returned by the asynchronous API that communicate that the API request has failed. For example, if you have sent a request to Amazon, your error values are CANCELED, ERROR. Use comma-separated values to define the multiple error values.
Configure how to get results
Result export (required): The export resource responsible for getting the final results of the originally requested task.
Configure how to process initial submission
Same as check status: Check this box if the initial asynchronous API response is identical to the check status requests. If the initial asynchronous API response is different from the responses that communicate in-progress status, enter the Resource path and Transform rules necessary to handle the initial response.
Resource path: This field displays if Same as check status is not checked. Specify the path for obtaining data from the initial response. You can use handlebars expressions to access all data returned in status and result messages.
Transform rules: Use this optional field if the asynchronous API resource returns responses in non-JSON formats. For example, if your target application is Amazon, the response data returns in XML format. You can convert the XML response data to JSON using Transform rules. See Transform Rules Guide for more information.
Click Save to save changes.
Click Save & close to save changes and exit the async helper.
Click Close to exit the async helper without saving changes.
1 comment
Tom Santiago Santiago My Transformation step is not being executed when applied to an Export that is using the Async Helper. I also added a PreSavePage script with a debug line to log the options.data value and this does not seem to be getting triggered either.
Is there any know limitations when using the Async Helper on an export (HTTP connector)?
There is very few support articles on the Asnc Helper so any knowledge you can share will be helpful.
