Freshsales (formerly Freshworks CRM) is an intuitive CRM with built-in phone and email, tasks, appointments, and notes, that help sales reps do hassle-free prospects.
This video demonstrates creating a Freshsales connection.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings.
Name your connection* |
Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections that you’ve created. |
Subdomain* |
Enter your Freshsales subdomain. For example, if your Freshsales account is located at |
API key* |
Enter your Freshsales API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom universal connector documentation.
Sign in to your Freshsales account.
Click on your profile picture at the top right corner of your portal.
Click the Pencil icon to navigate to Personal settings > API settings.
Copy API key.
