Set up a connection to Walmart
Walmart is an e-commerce platform that helps users to shop online.
Setting
Instructions
Name your connection *
API type *
Choose the API type depending on the Walmart API type you're connecting to (Walmart US, Walmart Canada, or Walmart Mexico). The settings then become specific to the selected API type.
API type: Walmart US
Setting
Instructions
Environment *
Select your Walmart US account environment (Production or Sandbox).
Auth type *
Choose your Walmart account authentication type (either Token or OAuth2.0).
Auth type: Token
Client ID *
Enter your Walmart US client ID.
 How to retrieve the client ID
Client secret *
Enter your Walmart US client secret.
Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
 How to retrieve the client secret
Auth type: OAuth 2.0
Seller ID *
Enter your Walmart US seller ID.
dataLoad.svg​​ How to retrieve the seller ID
  1. Sign in to your Walmart US developer account.
  2. Click My account.
  3. Select Marketplace.
  4. Sign in with your email address and password.
  5. Copy Client ID.
  6. Copy Client secret.
API type: Walmart Canada
Setting
Instructions
Auth type *
Choose your Walmart account authentication type (either Custom or OAuth2.0).
Auth type: Custom
Consumer ID *
Enter your Walmart Canada consumer ID.
 How to retrieve the consumer ID
Locale ID
Select a value for an English or French Canadian locale.
Private key *
Enter Walmart Canada private key.
Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication private key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
 How to retrieve the private key
Seller ID *
Enter your Walmart Canada seller ID.
How to retrieve the consumer ID and private key
  1. Sign in to your Walmart Canada developer account.
  5. Copy Consumer ID.
  6. Copy Private key.
API type: Walmart Mexico
Setting
Instructions
Environment *
Select your Walmart Mexico account environment (Production or Sandbox).
Auth type *
Choose your Walmart Mexico account authentication type (either Token or OAuth2.0).
Auth type: Token
Client ID *
Enter your Walmart Mexico client ID.
dataLoad.svg​​ How to retrieve the client ID
Client secret *
Enter your Walmart Mexico client secret.
 dataLoad.svg​​How to retrieve the client secret
Seller ID *
Enter your Walmart Mexico seller ID.
  1. Sign in to your Walmart Mexico developer account.
  5. Copy Client ID.
  1. Sign in to your Walmart Seller account.
  2. Click the Gear icon on the top right of the page.
  3. Copy the Seller ID.
    The Seller ID is usually found below the Company name on the left side of the page.
