Walmart is an e-commerce platform that helps users to shop online.
API type * |
Choose the API type depending on the Walmart API type you're connecting to (Walmart US, Walmart Canada, or Walmart Mexico). The settings then become specific to the selected API type. |
Environment * |
Select your Walmart US account environment (Production or Sandbox). |
Auth type * |
Choose your Walmart account authentication type (either Token or OAuth2.0). |
Auth type: Token |
Client ID * |
Enter your Walmart US client ID. |
Client secret * |
Enter your Walmart US client secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Auth type: OAuth 2.0 |
Seller ID * |
Enter your Walmart US seller ID. |
Sign in to your Walmart US developer account.
Click My account.
Select Marketplace.
Sign in with your email address and password.
Copy Client ID.
Copy Client secret.
Auth type * |
Choose your Walmart account authentication type (either Custom or OAuth2.0). |
Auth type: Custom |
Consumer ID * |
Enter your Walmart Canada consumer ID. |
Locale ID |
Select a value for an English or French Canadian locale. |
Private key * |
Enter Walmart Canada private key. Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication private key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Seller ID * |
Enter your Walmart Canada seller ID. |
Sign in to your Walmart Canada developer account.
Click My account.
Select Marketplace.
Copy Consumer ID.
Copy Private key.
Environment * |
Select your Walmart Mexico account environment (Production or Sandbox). |
Auth type * |
Choose your Walmart Mexico account authentication type (either Token or OAuth2.0). |
Auth type: Token |
Client ID * |
Enter your Walmart Mexico client ID. |
Client secret * |
Enter your Walmart Mexico client secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Seller ID * |
Enter your Walmart Mexico seller ID. |
Sign in to your Walmart Mexico developer account.
Click My account.
Select Marketplace.
Copy Client ID.
Copy Client secret.
Sign in to your Walmart Seller account.
Click the Gear icon on the top right of the page.
Copy the Seller ID.
The Seller ID is usually found below the Company name on the left side of the page.
